SIKKY intake manifold gasket install
seoul4korea
620
San Diego, CA
www.supraforums.com
1James;1993192 said:
No, that one will not work on the 1J, you will need the 1J specific one: http://www.driftmotion.com/Heat-Shielding-Gasket-1JZ-GTE-p/dm299.htm
It's only the gasket between the lowers and the head, so you'll need to reuse or source the upper/lower gasket. Some people like to spray copper spray-a-gasket when reusing old gaskets.
Actually they have a check out option to buy both gaskets for the 1J.
Fred, when are you putting out the single turbo install video?
