dumbo;1220017 said:it sounds as if the cps is probable, have you check it per tsrm, and coils and igniter. i would focus on that, but not exclude everything else. i would ground the bracket of your coil pack, and install the internal ground of your igniter for good measure. even if one of the coil packs has a open and was not working i'd say i tihnk it would still run on 4 cylinders, not pretty though. i wouldn't get wires from the dealer, nor a tundra. why not order ones for your car from napa or something, got my msd's from ebay-perfect fit.
EDIT: just read the first page. how did you get the EFI to top blowing?
I got the EFI to quit blowin by finding the short in the wireing on the O2 sensor , & another in the engine harness ... So Im not exactly sure which one fixed that ,
Today I checked the CPS itself .... Pre TSRM .... Its a gonner .
I did the coil packs also , They were fine & grounded also . I also did a spark test & get spark ,
I checked for codes & got a code 12 , again ... looked further into the TSRM & belive since the CPS wont send the RPM signal to the ECU , The engine will NOT start ,
So ...... Anyone have a CPS they wanna part with for a fair price . Ive seen em' on here before , & now that I need one I cant find nothing ...:cry:
