Senior Capstone Project (CAD Model Inside)
gurley0916
Gurley=Last Name not girl
Mar 10, 2008
1,138
Columbus,OH
Hey guys I'm an Aeronautical Engineering student at Embry Riddle and I thought I would share the aircraft that my team and I (7 people) did for our capstone project. We are in the first semester of the preliminary design of the aircraft and next semester will be the detailed design of the aircraft (structural design). My position on the team is the actual CAD engineering so the plane that I'm posting up consists of 90 hrs of work and is pretty close to what we want the aircraft to look like. The request for proposal that was given to us is listed below.
Anyways thought I would share this as this is what has been keeping me away from my supra for so long. My plans are to land an intership this summer before I graduate in December to hopefully get my foot in the door with industry.
1.0 Statement of Need (SON)
The Department of Defense (DOD) including the U. S. Air Force, Army, Navy, and Marines have determined a need for a survivable, fixed-wing, close air support (CAS) aircraft for the defense of land and sea resources. This manned aircraft will be deployed from land or ship and be capable of effectively destroying hostile targets in a high-threat environment in close proximity to friendly forces. The aircraft must be capable of striking targets with all existing, air-to-surface munitions at low or high altitudes or airspeeds as dictated by the threat. This aircraft will be versatile enough to replace all other aircraft designated to perform the CAS mission including the A-10. The aircraft will be extremely maneuverable at all altitudes and airspeeds for offensive and counter-offensive operations. The fully loaded, combat radius of this aircraft will be 200 NM with a 10 minute target engagement at high Gs .
2.0 Request for Proposal (RFP)
This Request for Proposal addresses the development of a manned, close air support fighter capable of defending ground or sea-based resources within 200 NM of the aircraft base.
3.0 Vehicle Design Specifications/Requirements
- Launched from land or carrier.
- Maximum take-off and landing distance for land operations of 8,000 ft.
- Sustained maneuver capability of: 5 Gs at sea level and 220 KTAS, 4 Gs at 10,000 ft and 220 KTAS, and 3 Gs at 30,000 ft and 270 KTAS.
- Combat radius of 200 NM with 10 minute engagement at high G (above).
- Carry a leathal load of existing air-to-surface munitions and a 20mm cannon.
- Capable of engaging targets at altitudes from ground level to 30,000 ft.
- Cockpit designed for high maneuvering at maximum pilot efficiency.
General Dimensions of the aircraft are 57.5 ft long and 64 ft wing span. The wing area is 1027 ft^2 and the aircraft is designed to have 35,000 lbs of thrust to meet the maneuverability requirements.
IBoughtASupra
4,455
Queens, NY
Well done.
Looks similar to an F16, no? The cockpit is in a similar position.
I like the weapon hidden under the cockpit in the fourth picture.
Well done. :)
Albert
May 13, 2009
1,710
Tempe, AZ
F16 Andy really?!?
Def looks like a hybrid of a F35 and F22. With a longer wingspan.
Why the the wingspan again?
IBoughtASupra
4,455
Queens, NY
Hey hey, you're the aircraft guy. It's the first one that came to mind and it looks like a similar cockpit. You know you're way more knowledgeable about aircraft/guns.
gats
Rebuilding... Slowly!
Mar 3, 2009
182
Sydney, NSW
gurley0916;1813812 said:
V5, V6 looks insane cant wait to get my hands on it. Do you have experience with it?
Have used V5 for about 5 years.
Simply amazing program! Would love to try out V6 also...
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
That is easily 10x cooler than my capstone in mechanical engineering. We did a little CAD, lots of fea and some burst testing.
So are you actually going to build any kind of prototype?
Sent from my ADR6400L using Tapatalk
gurley0916
Mar 10, 2008
1,138
Columbus,OH
Yes we build a 2ft wind tunnel model with the 3D printers for testing aerodynamics then build the wing box after structural design using composites and load it till it fails. We then see if the wing failed where we projected based on our analysis
Enraged
A HG job took HOW long??
21
Victoria, BC, Canada
I use V5, I think it's R19? Using it for yacht design. We're only scratching the surface of what it can do, it's an amazingly powerful software suite.
te72
Classifieds Moderator
6,604
WHYoming
Neat. :)
Taxpayer funded program? Or is this a private venture of some sort?
gats
Mar 3, 2009
182
Sydney, NSW
gurley0916;1813903 said:
What field do you work in that requires you to use CATIA?
I was using R11-R14 designing Armoured Personnel Carriers back in the early 2000's.
And similar to Enraged, only scratched the surface of its capabilities...
gurley0916
Mar 10, 2008
1,138
Columbus,OH
Do you guys use free form shaping alot? I was taught to build everything in Generative shape design. It looks like free form is a whole new ball park i might need to get involved in.
gurley0916
Mar 10, 2008
1,138
Columbus,OH
Well I have been working on this still and we finished our wind tunnel testing today. We used the CAD model to build a 1:32 scale model that was printed by our 3D printer. Our predictions were that the plane would stall at 18 degrees angle of attack and it stalled at 16 so it was a decent estimation. Here are some pics of assembly and testing.
https://www.youtube.com/watch?v=9iS7Mr0OFWQ&feature=youtube_gdata_player
