safc neo sensors
terror
Antibliss
Jun 13, 2008
242
Alaska
what are the differences between the hot wire, pressure, flap and karman sensors, which is used in the 1jz and what do the sub menus for each sensor do? thanks
dogdrake
148
Gadsden Alabama
The 1jz you need to use the pressure(for map sensor) setting. the 7mgte uses karman vortex (air flow meter) it uses freq. Hot wire is another type of air flow meter that measures air flowing across a heated wire in the airflow meter.The more air the cooler the wire . Domestics use this alot.Hope this helps.
isnms
United States of America
Oklahoma
i80.photobucket.com
8,873
RockPaperSwoRD;1537043 said:
7mgte uses a MAF, not a karman vortex. only n/a 7ms have karman flappers
Say what? The Karman Vortex is used in the 7MGTE as pointed out, and the Vain Airflow Meter is used in the 7MGE.
