big yoggz;1325393 said:
Hey guys well I have a fist gen safc and i was wondering if anyone can verify if the wiring diagram from a safc-II is the same for a first ten safc. I searched the forum and found the diagram for the second ten safc-II. Witch helped me understand how to wire it up. But I just want to double check b4 installing and finding out it's dif. Thanks
All AFC's are basically the same when it comes to wiring, excluding special features. In other words, an AFC & VAFC are the same except the VAFC has the extra wires for controlling V-TECH.
Here are the versions of the AFC:
Generation 1 - S-AFC:
Generation 2 - S-AFC Digital:
Generation 3 - S-AFC II & S-AFC II Black:
Generation 4 - S-AFC NEO:
To be clear, you have an S-AFC Digital, correct? If so, that's not a gen 1 - it's a gen 2.
Regardless, there's no reason for you to use the wrong manual.
You can get the appropriate manual here:
http://www.supracentral.com/manuals/apexi/
If you have a S-AFC Digital, the files that apply to your device are:
afc_manual.pdf
afc_manual_wiring.pdf
afc_manual_us_update.pdf
The files for all other version are in that folder as well.
