running lean
88supramaniac
chicopee,ma
my engine is running lean and my check engine light comes on.....any ideas?? it has a three inch downpipe. magnaflow high flow cat....three in chinaman v band exhaust...k and n intake..short shifter..upgrades ct26..redone headgasket....any ideas??
black89t
boost'en down 101
Oct 27, 2007
951
humboldt, ca
make sure your o2 sensor is working properly same with the maf sensor. and obviously see what codes you get.
also the tech section is better for something like this.
jdub
Feb 10, 2006
10,730
Valley of the Sun
88supramaniac;1323072 said:
that didnt help at all......
What didn't help...me posting how to pull engine ECU codes?
How can you possibly expect help if you do not post the specific code?
Dude - get a grip. Playing guessing games is not going to help anyone, mostly you.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Did you even look at the link I posted? If you can't do something as simple as pulling ECU codes, you really need to take the car to someone that knows what they are doing.
I'll tell you this, it is probably not the O2 sensor...guessing will get you nowhere fast on this motor.
Piratetip
Far From Maddening Crowds
1,177
69
MKE, WI
Did you even read the link that jdub posted?
Don't guess, perform tests and narrow your problem down.
Edit: jdub beat me to it :)
slowpra na-t
Permanently Banned
Oct 16, 2008
132
murrieta ca
check the codes it anit rocket science.... put the jumper wire in, count the flashes.
the code will tell you the problem.
GOOD LUCK!!
