i have the 1jz gte
from idle to 3000 slow but runs fine (normal)
from 3000 to 4000 it goes da da da da da da
untill i hit 4000rpm then the turbo boost up and running fine
first i had it set at 36psi running fine then some told me no
put it at 43psi thats what the 1jz runs
at 43psi it ran like crap so now
i have the fuel pressure set at 36psi now run better but not where it should be
took the plugs out and check them for build up nope fine
to give a better idea of the rough reving
if you power wash your 7m motor and the water get into the spark plug boots and the engine goes da da da da da all the time
thats what this is like between 3000 - 4000 rpm only for me
thanks
Shane
thanks
Shane
