ok i am putting my motor back togather and am having a bit of trouble concerning the rod caps. when they are loose i can spin the crank freely but when i torque em i can not spin the motor at all . i am torquing then in 3 steps 25lb. ft then 35 lb. ft and finally 47 lb. ft. it get harder to spin every step until 47 where it no go at all . my question is what could be causing this problem ? the crank and rods went to see the machinist and i had him order the bearings for it . he is reputable and does all the machining for the local toyota dealer. :dunno:
