Ok all, Im at my end with this Issue. Everything that I have done so far has failed to correct this.
Im going to list a few setting in hope that someone can lead me in the correct direction.
Maft Pro with correct Software.
Mainscale set to -25
AF Voltage is reading 2.7v to 3.0v at Idle which is correct
TPS voltage for Q45 Throttle body is sitting on .39v
Vehicle RPMs are 680-700which is fine
The vehicle Idles great.....
Problem is that at Idle my AFR is 12.3 per wideband and I have done everything known to man to correct this. only other thing I can think of is that my O2 sensor might be bad but if that was so I wouldnt get any reading correct?. All my settings in the MAFT Pro are set to the correct Manufactor settings for the vehicle and I have even Updated to V5.22. Can someone, Anyone give me some Direction on what the Problem is. yes its pretty rich smelling but I cant get this to higher than 13.6 and this is with the mainscare adjusted to -48
anything will help right now.
Thanks
Robert
Someone please help me out here.
Thanks
Robert
