Rev meter not working with conversion
MrOizo
205
Auckland, New Zealand
Hey peoples!
Just wondering if anyone has had trouble with the tacho not working particuarally after a conversion.
my supra was originally a JZA70 obviously with a factory 1JZ.
When i have changed to the 2JZ the tacho stopped working. Weird thing is when i start and when i shut the engine down, it jumps a few notches on the tacho...
followed the supras.nl wiring and have checked it several times. :/
soooo anyone know what could be the happenings here?
tissimo
Stock is boring :(
Melbourne, FL
What harness did you use? The MKIV Supra (usdm 100% sure, assume the JDM is the same) uses the ECU to drive the tachometer. What you need to do is run a wire from the IG- on the Diag plug (right by where the harness runs into the firewall on a usdm car) and connect it to the stock tach wire in the dash wiring.
edit: supra.nl wiring is wiring the ECU outputted tach signal (ll1 #29) to the IG1 #11 tach signal. Thats why there is movement but it doesn't work.
MrOizo
205
Cheers for the reply. So this is wrong for my setup?
running a wire from the -IG should sort this also. i am out of town at the moment but will give it a go as soon as i am back.
thanks.
tissimo
Stock is boring :(
Melbourne, FL
thanks.
Yes it will fix the tach. The JZA70 tach runs from a signal directly from the ignitor (same IG- Signal in the Diag block) rather then the ecu's signal of the jza80.
MrOizo
205
Cheers for that!
Will get on to it as soon as i have a spare few mins :)
Thanks.
mischief7m
Broke and Lovin It
Sep 13, 2007
507
Central Ma / Cape Cod Ma
suprastanger507mgte;1165880 said:
I agree with Tissimo. This is how I have it. I run a wire from the diagnostic/check box Tach signal to the black wire on the M1 connector for Tach.
rather than starting a new thread, i figured i would ask this here.
my tach on my 7mgte to 1jz swap is not working, i have signal on the ignitor, but none on the same wire in the car. my question is can i run my tach off the same lead that my SAFC takes signal from? or would this be too much added resistance?
sorry if thats a stupid question, but any help would be really appreciated.
MrOizo
205
Thanks guys! Hooking to -IG and then to gauge solved my problem!
Just putting most of it back together now. exciting!
Have to sort out the electric fan and then its cruise-able :)
