replacing injectors
AndyMac
268
Canberra Australia
Hi guys,
I have used the search function but couldnt really find a good thread that walks through changing out the standard injectors.
If anyone knows of one that would be great.
Also I am changing with RC injectrs with EV1 clips so if there is a thread with how to wire the new ones even better :)
thanks in advance.
QuebecmkIII
50
quebec
rayall01;1339293 said:
maybe it's just good fun!
:bigthumb:
And if you don't want problem, it's a good time for change the fuel damper bault with a stainless fuel damper bypass hose...
I don't know for the other people but for me after having removing that bault, it leak on the top, I change it with an other used one, same thing...
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
I JUST put my 550's in and didn't completely remove the tb. I left the two hoses on the bottom connected and just moved it out of the way when needed. I also didn't remove what he's calling the "valve". For what that's worth...
Either way, it's a good write up for you to follow.
