first off i already have the tranny out. there is oil everywhere, in the bellhousing, on the fw bolts, the clutch disk, eveywhere.
the clutch is a spec stage 2, i put it in this last summer(didnt bother to do the RMS then)
Now, i cleaned the fw and pp with break parts cleaner and they came pretty clean. But my disk is now kinda brown oily colored. how do i clean it? break parts cleaner? should i even bother cleaning it or will it clean itself when i install it and use it?
I said above that the pp and fw came clean when sprayed with break parts cleaner. however on both of them there is a brown streak/line about .25in thick all the way around the fw and pp. is this something to be worried about?
The RMS i bought came with the gasket for the RMS housing, which from the TSRM i gather that you dont have to remove to replace the RMS. However how do i know where it is leaking from, the RMS or the housing, or could it be both? it also looks like i would have to pull the oil pan to get the RMS housing off the block, true? should i bother with it? do i have to drain the oil to replace the RMS?
And lastly it looks like my EGR is leaking, fluid ontop of the bellhousing, on the coolant hardlines, and under the EGR. I have the EGR gasket already. My question is: is it possible to replace the EGR gasket from under the car with the tranny out? What is behind the EGR plate? do i have to drain the coolant?
well thats about it for now, i know it was a long post and thanks in advance everyone. happy new year btw.:icon_bigg
