ok, so ive gone through every page and tried searching but cannot really find what im trying to find out. so i already have a bunch of parts for a rebuild but i am wondering if anyone has other suggestions or anything. i want to know what else i need basically.
what i have(came from Mizumo Auto):
NPR pistons, .020 over
NPR rings to go with it
ACL Main Bearings STD
ACL Rod Bearings STD
ACL Thrust Washer STD
Full Gasket kit
Water Pump
Oil Pump
Timing Belt
What I KNOW i still need:
ARP Head Studs
Metal Head Gasket
Vacuum Hoses
Machining
What else am i missing?
What should I expect to pay for boring, resurfacing, valve job?
Should anything else be machined? (other than timing plate, head and block surface, and obviously cylinders bc im going with larger pistons.)
Also, before anyone recommends forged pistons, i know, i want them, i dont have the money for them. i already have cast pistons sitting in the garage, still in the packaging of course. Sorry if this has been covered eleventy billion times. Thanks in advance.
Full Gasket kit
Water Pump
Oil Pump
Timing Belt
ARP Head Studs
Metal Head Gasket
Vacuum Hoses
Machining
