How do I remove the lens from it's frame? There is some dirt and mold trapped inside the light from water leaking into it and I can't get to it without taking the lens off from the frame. Any info? Thanks
There are 6 press in pins, they look like small nails on the inside of the light assembly that appear to hold the lens together. I haven't jumped into separating them yet...was thinking I'd convert to an 89+ tail. If you're feeling froggy you could pull those out with a pair of needle nose and see if you can open it up. gl.
