Check out the Oil and Lube section on the main page, all you need to know about it in there, brought to you by none other than Jdubmjmendoza;1176682 said:i am just wondering what the best gear fluid would be to put in the rear diff. from what i was told 80w-90 is the right fluid but i want to know what you guys put in your rear diffs.
jdub;1183652 said:It's Ford friction modifier...it allows an LSD to "slip" for proper operation. I would start with one oz.
Red Line 75W-90 is another good choice and it has the friction modifier already in it. On a high mileage LSD, you may get clatter with Red Line.
jdub;1184470 said:If you put Red Line in it and it clatters, it's high mileage![]()
topdog849;1711645 said:be sure not to use any fluid with friction modifiers.
