Re-installing the cam gears, new timing belt, timing the 1jz.
SuperNova
93
Grand Prairie, Texas
Does anyone know of a thread that tells you how position the cams and time the 1jz? I'm in the process of putting my motor back together and this is my next task.
Do I just put the cam gears on, then position the cams with the mark facing straight up and put cylinder #1 at TDC?
Thanks.
nctexan
268
Houston
This may seem like a numskull question to most, but if you are re-using a timing belt, why do you have to place matchmarks on the timing belt and camshaft timing pulleys? Every part of the belt will eventually pass the same points on the pulleys right? I must be missing something very basic.
