Has anybody bought one? Im in the market for a clutch kit for my daily driver im building and would like to know if any members have any specs, review or experiences with this clutch.
http://www.horsepowerfreaks.com/partdetails/Ralco_RZ/Clutch/Clutch_Kits/Stage_2_Carbon_Kevlar/16857
Ralco RZ Stage 2 Carbon Kevlar Clutch Kits
Ralco RZ Stage 2 clutch kit is a step up from their Stage 1 clutch kit. This is a versatile set up for the street and on the track.
It provides a smooth engagement yet it can hold more power over stock clutches. The clutch kit includes only the highest grade components from the world's leading high performance clutch manufacturer.
The Carbonized kevlar friction material is used on all Stage 2 clutch kits to have higher burst strength and heat tolerance. The Heavy-duty pressure plate is heat treated with a chromoly hub and retainer rivets to increase strength and reliability. The Ralco RZ pressure plate features special single diaphragm design to increase clamp load. It features an induction hardened diaphragm, CNC machined castings, stronger drive straps and rivets. Ralco RZ pressure plate provides smooth and precise feel with easy modulation. All Ralco RZ pressure plate is load tested on a special testing tool for quality assurance.
Includes:
•Ralco RZ Stage 2 Heavy-Duty Pressure Plate
•Ralco RZ Stage 2 Carbonized Kevlar Disc
•Release Bearing
•Pilot Bushing
•Alignment Tool
Includes:
•Release Bearing
•Pilot Bushing
•Alignment Tool
