Hoping you can help or point me in the right direction - thanks in advance
Problem: when I removed the transmision for the car, the mount only had two of the four bolts holding it on. After the engine/trans was removed I looked at the mount and the other two were stripped - thank you previous owner-
How do I get to the other side, and are the just nuts that I will need to replace?
Hope I explained the problem clearly
