Sweet! Nice pictures.
Can you measure the shaft length, un-splined shaft diameter, spline count, and spline cut length of the input shaft? Also, the input shaft length measured from the bellhousing/transmission mating surface to the end of the shaft (motor side). I'm trying to get a good, concrete comparison with the R150
Thanks a ton if you can get these!
Drew
