as the title says, car drives perfect when cold, but after about 30 minutes of driving, it will be hard to shift, especially into 1st (from a stop).
things i have checked/done:
-adjusted clutch pedal to have more travel (release clutch more)
-verified tranny fluid level is good
it is really starting to get annoying when i get stuck in rush hour traffic. my next idea was to change the tranny fluid to some redline, but i have synthetic in there right now that i never had a problem with when i used it in my other tranny a few years back.
i was guessing MAYBE the clutch disc is not sliding on the input shaft anymore, and once the disc/flywheel/pp material warms up and expands, it's like i'm not releasing the clutch enough cause it's partially grabbing. only reason i think that is because i have adjusted the clutch already, and the car (if on perfectly level smooth ground) will kinda move forward a bit when i try to put it into first (like when the disc is in backwards).
