R-134A Retrofit Kit
LumbChuck
59
Charleston, SC
Is there a complete kit that you can buy to change over to R-134A ? I have searched through the threads and have not been able to find this . I know someone has asked this before . I would like to get a "Parallel Flow Condenser" with the kit . My original compressor (197k) went out , so I guess I need to go this route . I could use any info on this . Thanks
And this has what to do with turbo motor 7M's?
Thread moved...please pay attention where you post.
Jeff Lange
Administrator
4,918
4
Calgary, Canada
jefflange.ca
Jdub was referring to the fact that the 7M-GTE forum is for posting threads related to 7M-GTE specific topics. The A/C in the car is not a GTE specific topic and therefore does not belong in the forum you posted in.
As far as conversions. Toyota offers all the parts to do a conversion, but if you're looking to change/upgrade components beyond the original specifications, I don't know specifically where to get those parts.
Hopefully someone will chime in who has done some A/C upgrades on the A70.
Jeff
EDIT (Toyota Retrofit Information for A70 Supra):
88840–33020 - Retrofit Kit, R134a
88471-12070 - Receiver/Dryer, R134a Conversion Type
08885–09107 - ND Oil Type 8 (250cc), 120cc Required
90099-14120 - R134a Discharge O-Rings
90099-14119 - R134a Liquid O-Rings
90099-14121 - R134a Suction O-Rings
90099-14122 - R134a Pressure Switch O-Rings
R134a Charge Amount: 650g
Satan
Tampa
Do a search for parallel flow condensor. I had one made and retrofitted to R134a. Posted all the specifics, in this same section (I believe).
Kai
That Limey Bastard
08885–09107 - ND Oil Type 8 (250cc), 120cc Required (100cc for 1986 Models)
Jeff - whats the approximate line cost of each of these items?
