Ok...I'm starting to do the fuseblock wiring. I know I am supposed to hook a white wire from the Alternator block from the JZA70 to the square fuse block connector (the one with the two pink wires and the red looped one.)...but in the spot that the white wire corresponds to already has a yellow wire comming from the MA70 Alternator connector in it. What should I do?!?
Thanks in advance.
Thanks in advance.
