There will be two oil feeds on the exhaust side of the block, also, on the.. exhaust side inside the block will be small oil squirters that spray oil on the bottom of the pistons.
thanks and how can i tell if the botttem end is good ....because someone is selling a 2jz turbo bottom end alone for $200 and thats kinda cheap and he said its good !
if its that cheap its probably not good unless he says it a gte bottom end but its really a ge bottom end. they only way you could tell is to take it apart
