I know you guys have seen the commercials, ferrari is backing the product. Has anybody tried it yet or does anybody know if this stuff is really a better oil? Expensive?
Ric said:What ever happened to factory Toyota oil? Thats all I use.
If you're looking for more power? turn the boost up
Doward said:Pennzoil Platinum is a good oil? I thought it was a GrpIII base?
gixxer750 said:I know if quaker state q sits in a back room for say... six months... solids settle to the bottom. I have whitnessed this first hand.
mkIIIman089 said:The Shell engineer at the PRI show, when asked about running their Q Racing oil in a street car said nothing about it not having enough additives of any kind. He said what it would do though, is create a lot more deposits (extra spike of EP type additives) in the exhaust that could wreak havoc on things like 02 sensors.
mkIIIman089 said:I should have prefaced that with "although he didn't recommend it".
Now... the Amsoil guys, they would tell you, you could use any of their product in anything and would GAIN horsepower. I have personally experienced what I believe to be oil related deposits from running a Series 2000 oil.
OK, back on topic now.
mkIIIman089 said:It's possible... but I have my doubts since it was certainly not the first oil I had run with high levels of detergents. It was not as much "gunk" as it was a caked powdery substance that was building up anything that wasn't smooth. (Might have been something in the fuel I suppose too, but thats a fairly slim chance)
This is a strange experience posting in this section...
AGlobalThreat said:I'm starting to lean toward using redline 5w30 synthetic. I currently have 5w30 oil from oil stop in the engine (I've been told they use some kind of oil from chevron?). The 5w30 works great, cold starts are no problem, I have no leaks, and so far so good for boosting on hot days.
Now after reading the threads in this section, I'm led to believe that if I pay the price for redline I go 8,000 miles before changing the oil, change the filter at 4,000 miles, and basically it will make the engine last forever, granted I don't push it over the limit. That sounds great to me, I don't mind paying more for what it does to the seals and internals, especially if I change the oil at almost 3x what I've been doing (3,000 or so miles).
Also, what filter should I use for my 1jz? I've heard the v8 tacoma one is a nice tall one that fits.
I would still like info on Q horsepower though, especially if it's only $3 a quart!
foreverpsycotic said:the 1j, 2j and 7m all use the same filters just as a FYI
AGlobalThreat said:Then what is a good filter to use for the 1jz while retaining the stock size? I can't exactly go to the auto parts store and tell them I need an 87 1jz filter
