Pulls to the right...
Status
Not open for further replies.
Kai
That Limey Bastard
Aside from the wheels having possibly thrown a weight (i get judder over 60mph), is there anything that can cause the car to drift to the right? If i get it on a perfectly flat, straight surface, it wants to pull me over. I had considered a sticking caliper, but i'm going to be replacing the front discs & pads in the next week or so.
Would worn lower ball joints be the main culprit here, or track rod ends? There is some play in the steering, although minimal.
shaeff
Kurt is FTMFW x2!!!!
9
Around
Does it feel like it's pulling from the front end or the rear? The rear knuckle bushings, when bad, will cause the rear to kindof wander around a bit.
Mk3runner
2,033
Nor Cal
Alignment. How long has it been? My car would steer straight but at speed would vibrate. Got it adjusted, perfect afterwards.
martin p
1JZ-GTE powered Supra.
Feb 5, 2006
215
East coast. UK
Kai;1348469 said:
Well, in the UK, Kwik Fit do tracking...out here everything non French gets frowned at and 'tutted' over. There may be a place I can go, but what do you guys pay for alignment?
kai, local Kwik fit near me wanted £300 for 4 wheel alignment But my tyre specialist wants £50! So shop around, Between 50-125 is about right. Hope your camber bolts are not seized or you will have problems!
rayall01
901
Westfield, ma
Doward;1348187 said:
Alignment (toe, specifically)
Have to point out something. Toe is not responsible for pulling. If it's toe out, it will dart from side to side, if it's toe in, it will drift from side to side. A constant pull to one side, is caused by camber, or caster, at least as it pertains to alignment, as opposed to some type of mechanical problem.
gaboonviper85
3,236
Northeast Philly
did the thought of one wheel having more toe then the other ever cross your mind before you wrote this bullshit?
I wonder how long it will be before you're banned from replying to tech questions
rayall01
901
Westfield, ma
I am ASE certified in suspension and steering. What's your certification in?
Think carefully about it. It may come to you why you are beyond fucking wrong about this.
Status
