al lewis;1719931 said:
I think this is the answer cause theres no blue smoke what so ever under boost or when its heated up as you said. Is this gona be a problem for me? Is the engine being damaged? :nono:
Uhhhh. Depends what you mean by "problem". heehee. *IF* this is indeed the problem you have some piston ring problems. Either one cylinder, or more, but from the *puff* you describe plus the miss probably just one cylinder. Um, piston ring shrapnel could do some damage or just sit in the sludge in the bottom of your pan forever. IDK.
You would do well with changing the oil a few times along with the filter just to get any shrapnel out of the oil system.
Beyond that, unless you are skilled enough to re-ring the pistons I don't know what kind of real problems you will have other than an occasional misfire and one cylinder needing a good heat up before working to potential. Over time and stress, it may be likely that the rest of the ring will explode too, but not always.
You could check all of your spark plugs to see if one (+) plug is oil burned fouled. That would be the easiest way to determine anything.
Any piston slap on cold start? Check engine light on miss? No smoke on start up probably just because oil isn't thin enough (Hot enough) to blow-by yet.
No piston slap and blow-by only for a short period. Not a serious problem. Add thicker oil.
Sorry: edited to answer your last question. If you oil/filter change and maybe go as far to clean up the pan, 2X you've probably removed much of the ring that would cause real damage. Oil change regular and sooner than later afterward. It won't stop the problem but it'll live. Since there is blow-by enough to notice smoke you are eating a lot of oil. Check it regularly like every week at least and always have a litre in the hatch. Other than replacing rings, you'd be stuck with the symptom.
---------- Post added at 07:06 PM ---------- Previous post was at 06:52 PM ----------
Whoa! You are running 10:1 WOT? Crap. That's rich. What boost are you running?
