I understand the benefits of Synthetic Motor Oil, but when can I start using it on my rebuilt motor? I have read or heard of mileage ranges from 500 to 10000. I would like to hear your opinion on this.
Thanks
Thanks
JustAnotherVictim said:After the initial run should the oil and filters be changed and then refilled with 30w again until the 500+ mi point?
rot 90na-t said:What is the recommended brand, weight, and type of oil one should use to break in a fresh rebuild with forged internals?
starscream5000 said:Well said John . What do you think is the most crucial part? Waiting until the oil is up to operating temps before getting down on it? I've heard the first 20 miles is the most crucial part in determining that the piston rings are properly seated. Granted, it shouldn't take 20 miles to do the hard passes. Does 5-10 hard passes soud ok? With varying cruise speeds/RPM between the first 5 passes and the last set? What gear do you recommend doing this in? Do you recommend downshifting to keep the RPM's up high when decelerating from the hard pull?
starscream5000 said:But WOT from 4-4.5K RPM's, then start down shifting... What RPM would be best to put it in once you down shift? 5-5.5K? Again, 3rd gear good enough? or 4th?
Tire Shredder said:Jdub,
what's the theory for using a constant weight oil? I'm assuming when you say 30w it is NOT multi viscosity oil? It was my understanding you want the car to be warmed up before you start the 3/4 throttle pulls to seat the rings. If so, then how could it hurt running a 5w-30 or 10w-30 for the initial startup? I'm unclear on the theory behind this, only hearing "use 30w" all over supramania.
to save me posting a second question, if you can convince me a monograde oil is the way to go, would something like the castrol HD30 do the trick?
Thanks, Steve
jdub said:Nope...you can go straight to a syn oil. Just use a good filter (Wix or PureOne) and a 0W or 5W-30...German Castrol (0W-30) is what I like.
