Progressive power steering
dragracer
GearHead
Oct 31, 2005
221
Churubusco
Do all 89 turbo cars have pps ?
Is there a computer and where its located ?
Any pics of rack?
Reason I'm asking I'm finishing my car and unsure if the rack has been switched. Plus I don't have the computer if there is one.
Thanks
89supra7mgte
797
colorado
I dont know exactly how it works, but the tsrm shows the pps system in the diagrams. I know it uses vacuum on the pps switch to aid in easy of turning at lower rpms i believe. Not entirely sure though. check the tsrm for proper explanation
whitemike
1,164
Winter Park, Florida, United States
Here's a crappy pic, car is a 91. You can see the plug there as well.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
89supra7mgte;1596510 said:
...I know it uses vacuum on the pps switch to aid in easy of turning at lower rpms...
I'm afraid you're confusing the air bleed idle-up feature with PPS. Different systems with different functions.
Nick M;1596525 said:
...A solenoid blocks or allows flow depending on speed...
Not solenoid. Proportional control valve. Close enough for this gang though...
dragracer
GearHead
Oct 31, 2005
221
Churubusco
I understand how it works.
I just bought this car as a shell years ago which was pretty much stripped.
Bolts on rack were loose and was unsure if it was swapped.
Where is the computer mounted?
Thanks for the rack pics.
Thanks guys
