I've been having problems with the starter for a few years now in cold weather. Usually I just give it a few raps with a wrench or something, and it starts fine after that. Today however, that did not work. Tried a few times, got nothing, so decided to wait till it had warmed up a bit outside. Came back to try again, now instead of getting nothing, I get the rapid clicking coming from the starter.
The smaller wire connected to seems to be in fine condition, however the plastic piece holding the connection together had broken, so it slid out of place rather easily. The wire could also slide back and forward inside the connector. So I took the connector off, and attached the wire directly to the post on the starter. Same click click click. The smaller wire is getting 6 volts when I am trying to start it. Is that how many it's supposed to be getting? I've heard that it is most often the wiring, and not the starter itself. I'm hoping this is the case, but what would I check next?
Thanks
Thanks
