the only chance of the ceramic braking off would be if it is struck by a object. like if a rock were sucked up into the turbo. heat and vibrations will not damage the ceramic. unless it is over 1200 deg. temp
if u drop a wrench, sharp or heavy object on the intake... the ceramic may brake on the out side, but it would take a lot of force to crack the ceramic through the pipe.
the v2 doesn't have the port to attach the pipe from the bov to.
for example , stock intake has 3 ports, like V1, V2 only has 2 ports.
yes there will be a seprate order for the NA intakes
i'll have to get the design worked out first probly be around the same price just guessing.
