It may benefit someone else on here if you were to tell us exactly what problem you're having, and the solution you have found.
Not long ago I had a problem trying to snake out the high pressure steering hose out without removing the rack. I was never able to do that so I cut the old hose in two and pull it out. I replaced it with a custom hose that I had made at a shop here in town. Very similar with what Driftmotion sells. That was my problem, and solution.
