I saw someone else having this same problem posted. However, I don't know what my issue is. Here it goes; fresh rebuilt motor installed in the car. Battery relocated to trunk. When I hooked up the battery the door panel lights come on when they are open, door ajar dinner dings, headlights come on and function. All fuses are good. When I turn the key to start, relay in passenger floorboard clicks, as well as something clicking directly behind brake distribution block. With a meter down at the starter, I have full time 12 volts at the terminal and I get 12 volts at the signal wire when someone turns the key. When I turn the key inside the car, I hear various clicks as stated. The relay in the kick panel clicks once, the clicking by brake block clicks twice. The orange tail light indicator above the TEMS light lights up when the key is turned. Additionally, I have no piwer in any of the diagnostic box ports. I need an OG here I will be very great fun for any insight here guys, really. I've read tons of threads and can't narrow down further than I have already. I've read about a starter kill switch, where is this and can I test if it's activated? The security light isn't lit up if anyone wonders and I think the alarm has been removed I can't find the box for it.
