Well the car has ALWAYS been started fine even in 20-F weather. It's a 87, 7m-ge, with 70k miles on the engine.
Brand new starter, plugs, alternator, battery, and other misc things.
So, I go to start the car (Just filled it up with gas), and it barely fires. After 2 minutes of constantly trying, it starts to rise (RPM's), get's to 500Revs and slowly dies. It does this for about 10 more tries.
I try giving it a little gas, and nothing.
After 10 minutes it finally idles properly, but hesitates when floored (Until completely warmed up).
Also I am seeing between 40-80psi on the oil pressure gauge, reading 14 volts, and 20inHg. at idle (Vac pressure).
So here's what I've got from searching.
1. MAF - plugged in properly
2. Check codes - Only reading the knock sensor (The wire is cut)
3. Plugs & wires - Brand new, gapped, and all installed fine.
4. Vac leak - 20 inHg at idle, about 25 at de-acceleration, and around 2 when given 80-100% throttle
5. Throttle position sensor - Plugged in, and no codes are being given
6. Cold start injector - Plug is in, I had the injectors (All 7) sent off and cleaned along with the fuel rail.
Compression is fine.
Can anyone help?
Thanks guys!
Matt
Can anyone help?
Thanks guys!
Matt
