Ok well everyone i was going to do a full rebuild and everything if you have read my post about it then you know already. But i was looking and i didnt know if anyone has heard anything good about Porters Performance Stage 3 crate motor that has
Machined 7M-GTE Block
CRI Machined Crankshaft
ACL Main Bearings
CP Pistons
CP Piston Rings
Eagle H-Beam Connecting Rods
ACL Rod Bearings
ARP Rod Bolts
OEM Main Bolts
OEM Freeze Plugs
High Temp Paint
Head Work Includes:
Machined 7M-GTE Head
3 Angle Valve and Seat Grind
Engine Pro Valves
Viton Valve Stem Seals
Supertech Dual Valve Springs
Cometic Multi-Layer Steel Head Gasket
ARP Head Studs
Accessories:
Gates Racing Timing Belt
OEM Timing Tensioner
OEM Timing Kit
Cardone Water Pump
ITM Oil Pump
But i wasnt sure if anyone had heard anything bad or good about them. So if anyone has any info please feel free to tell me.
Thanks
ACL Main Bearings
CP Pistons
CP Piston Rings
ACL Rod Bearings
ARP Rod Bolts
OEM Main Bolts
OEM Freeze Plugs
High Temp Paint
Head Work Includes:
Engine Pro Valves
ARP Head Studs
Accessories:
OEM Timing Kit
Cardone Water Pump
ITM Oil Pump
Thanks
