PLX devices wideband o2 help.
scottiedawg66
Bay Area Ca
what is needed from PLX devices to make my autometer AF gauge to output wideband data? I beleive all i need is a translator box, and WB o2 sensor. Is there anything else. Is it possible to replace the stock o2 directly, and translate to NB for the ECU, then back to WB after the ECU? Anyone get this to work or should i settle for the ugly (IMO) digital output box?
~scott
Ckanderson
2,644
The beach
you need the PLX m-300 and translator box. This is what I use. No the bosh sensor wont plug into the stock location. You have to use a oxygen sensor bung. if ya wanna check out my setup ya can.
