Please help!!
supraboy
77
washington
I almost have my head off, but I can't get the intake cam out thus can't get a good grip on the head bolts on that side. What am I doing wrong??
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
You don't need to remove the cam to get to the head bolts. You may need to rotate the cam to #1 TDC/compression, but you don't need to remove it. I've never removed the cams when pulling a 7M head.
P.S. A more descriptive thread title than "please help" would be useful.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,231
Atlanta
It sometimes gets 'jammed' as the caps are loosened, but all thats required, is to press down on the cam evenly to get the the tension off of it.
Which is why it has a specific sequence to loosen the bolts and what orientation the cam should be in.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,231
Atlanta
Welp, since he cant get the cam out, im assuming he didnt follow the tsrm disassembly procedure, and thats why it's jammed.
