Pic request: 7m on a stand
Tire Shredder
569
Oshawa
Hey guys,
I need a pic of a 7m on an engine stand, from the front/intake side....would be nice if it highlighted the lower alternator bracket.
my motor did not come with a lower bracket, bolts or A/C bracket. I'd like to know if it requires the A/C bracket to bolt to the block and exactly how it attaches. a word response would be just as helpful as a picture. thanks!
Yellow 13
Lurker
Apr 4, 2006
2,308
Fairfield, California
This is the best I can do:
The alternator bracket is separate from the A/C bracket. You don't need the A/C bracket for the alternator.
Yellow 13
Lurker
Apr 4, 2006
2,308
IJ. said:
But the Alt bracket sandwiches between the block and the AC bracket if that helps. (If you delete the AC bracket you'll need a spacer the same thickness)
Eh?
My alternator bracket sits on the front of the timing belt case IIRC.
(Its been a few months since I got to look at my 7M :cry: )
I just removed the A/C bracket and compressor thinking it wouldn't affect anything. does it?
DOH Sorry I have it arse about!!!
Block>ALT Bracket>AC Bracket
If you bolt the AC bracket on first you can't fit the Alt bracket (I knew there was something annoying about this bit)(guess who forgot this time)
