heh well after searching this forum didnt turn up, i searched *another forum* that shall remain nameless..
rather than deleting this thread, i'm just gonna post that info in here in the hopes that it will someday help some other soul who only thinks to search this forum.
7M valve shim donors
If you ever struggle to find cheap or variety of shim thicknesses a little searching turns up some places you can look for shims. Most valuable is the fact that honda has shims thinner and thicker than toyota offers.
* Some common compatible valve shim donors: 16-valve 4A-G(Z)(E)
* 4A-F(E)
* 7A-FE
* 7M-G(T)E
* 3S-G(T)E
* 5S-FE (pre-'93)
SOB shims
25mm diameter Used in Honda ('79--'83 4-cylinder CB750, 900, 1000, and 1100 series engines,
and 1050 CBX 6-cylinder engines, and others), Yamaha (V-Max, and the FJ1100/1200 series),
Triumph 3- and 4-cylinder liquid-cooled motorcycle engines, and older Toyota car engines.
HotCams makes shim kits but i found they dont carry the larg sizes. Honda dealer local to me had all but 1 shim i needed and all were like aprox $5 each as compared to toyota pricing of $8+ (canadian) im not sure what the toyota shims are but i remember people saying they are arround 10 bux each.
So simply raid your local pick a part for your normal range of shims and order any thicker ones you might need.
Thickness, Honda Part No. Toyota Part No. *
mm (inches)
2.30 (.0905) 14901-422-000 # n/a
2.35 (.0925) 14903-422-000 # n/a
2.40 (.0945) 14905-422-000 # n/a
2.45 (.0964) 14907-422-000 # n/a
2.50 (.0984) 14909-422-000 13753-74010
2.55 (.1004) 14911-422-000 13753-74030
2.60 (.1024) 14913-422-000 13753-74050
2.65 (.1043) 14915-422-000 13753-74070
2.70 (.1063) 14917-422-000 13753-74090
2.75 (.1083) 14919-422-000 13753-74110
2.80 (.1102) 14921-422-000 13753-74130
2.85 (.1122) 14923-422-000 13753-74150
2.90 (.1142) 14925-422-000 13753-74170
2.95 (.1161) 14927-422-000 13753-74190
3.00 (.1181) 14929-422-000 13753-74210
3.05 (.1201) 14931-422-000 13753-74230
3.10 (.1220) 14933-422-000 13753-74250
3.15 (.1240) 14935-422-000 13753-74270
3.20 (.1260) 14937-422-000 13753-74290
3.25 (.1280) 14939-422-000 13753-74310
3.30 (.1299) 14941-422-000 13753-74330
3.35 (.1319) 14943-422-000 # n/a
3.40 (.1338) 14945-422-000 # n/a
3.45 (.1358) 14947-422-000 # n/a
3.50 (.1378) 14949-422-000 # n/a
im gonna be doing a search shortly to make a list of vehicles and model years with the above engines. ill post that here as well.
