Os Giken Push pull converter thrust bearing replacement?
paradox616
472
Melbourne, Australia
Hi Guys,
So i picked up a os giken push pull converter for my R154 gearbox, the thrust (release/throwout) bearing was shagged, i got a clutch shop to replace it. the one they used was a larger profile (in depth) and as a result when bolted up the thrust bearing pressed on the clutch fins partially releasing the clutch.
So i pulled the gearbox out and have been trying to find a suitable replacement that is the correct profile, I've done a bit of searching with no results. surely someone has replaced this part before.
Does anyone know what the bearing is from/have a part number for it?
You can see it below, its for this style movement converter.
Thanks.
Inygknok
Tropical Paradise
Sep 22, 2005
488
Puerto Rico
Have you tried it out yet? I'm interested in knowing if it's actually functional and how much it can handle. I should use the search function........
ricoboost
90
quebec
and how do you adjuste the bearing after? i have a used clutch with the push/pull converter and i dont know how close to the pressure plate it should be thanks
