Opinion on Transmission cooler
Who
I was cruising the junk yard and I came across a small oil cooler that caught my eye. I thought this small oil cooler would be easy enough to mount and not block a lot of air flow. I should mention that I plan to add this cooler in addition to the stock tranny cooler in the rad. The dimensions are 9 x 2 x 3/4 inches and I want use it as a transmission cooler. I found a photo on ebay that is dead on to the one I found. What do you guys think. See my signature for my mods and take note I live in sunny, hot FL. Thanks.
"To small" wasting your time and effort.
"To large" tranny fluid temp will be to low.
"Other" Flame away :cry:
Dimensions are 9 x 2 x 3/4 inches.
SideWinderGX
733
I ended up installing a B&M SuperCooler (one of the larger ones) when I installed my Fluidyne radiator. All I keep hearing is 'A340E's hate getting hot!' so the bigger, the better, and the less problems you'll have down the road!
But yeah, that cooler is a wee bit small ;)
