oil temp gauge
fastazzsupra
46
South Carolina
I am still running the stock oil filter housing. Where can I put the oil temp sender? Do I have to buy a remote filter kit? If so, what brand is the best and most reliable?
wiseco7mgt
dirty mechanic
Aug 12, 2007
811
queensland
fastazzsupra;1478203 said:
What about using a sandwich plate between the oil filter and housing? Is anyone using a setup like this? What brand remote mount are you using IJ?
The idea of a remote filter is to give you better access as well as the flow increase, so adding a sandwich adapter still makes changing the filter a PITA.
The turbo kind of blocks off easy access.
