I am starting to assemble my motor and after the rebuild (rod knock) with all kinds of forged goodies. And I was reading that the Group A's use the heavy N/A block with out the oil squirters because they used forged pistons an they were not needed. I believe my rod Knock was caused by 3 of the oil squirters being stuck open. So my question is can I just block them off, and if so should I shim the new oil pump still or just leave it alone. I checked with the dealer and the new bolts for the squirters are over $12 ea and there are not anymore in the states so it would be at least a couple weeks before the could be in from japan?
