I just finished going through all this, seems alot of people have been going this route lately
Heres a post I just made in my thread on the topic!
___________________________________________________
Heres the list for my all out (short of an accusump and modified pan, and without going dry-sump lol) oiling system:
B&M Supercooler, 70274
Permacool Dual oil filter mount, 3/4-16 thread
Permacool spin on oil filter adaptor
These next three are for oil pressure and temp senders, you can use the extra 2 ports on the filter mount, but I decided to go with post-oil cooler readings:
Aeroquip female -10 to male -6 reducer
Earls -6 to 1/8" NPT
Earls 1/8" NPT Tee
Mocal 180* Thermostat, -10 fittings
Aeroquip -10 socketless hose (I hope 13' is enough!)
Aerolube for hose assembly
8 Socketless Mocal -10 hose ends (only need 6 if you use filter mount for sensors)
1 Aeroquip -10 tee (again only needed if you tap into the line for sensors)
4 Socketless Mocal -10 90* hose ends
6 Mocal 1/2" NPT to -10 adaptors
Almost forgot you'll need a N/A Filterstud, and some teflon for the npt fittings
I think that just about covers it!
This setup used in conjuction with wix and trasko filters, should complement my new oil squirters, shimmed pump, and Arz oil pump hardline! Lots of volume, without building (or losing) pressure! That's the goal at least
Edit: After actually going through and installing this system, i had to make a few changes, i ended up needing 4 more 90's instead of straight hose ends, as well as needing to use a Canton filter adapter (90 degree swiveling) for clearance issues
