oil pressure sender
supra1008
1,179
Philadelphia
i put a rag over it and used channel locks to get it off and on. no problems, no scratches. Then get the adapter hose from driftmotion, add some thread sealant and screw everything in and you're done!
oh. you might have to move the ac compressor to get to the oil pressure sender on the 1j.
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
MArk, A large socket should get it out. I forgot what size it is but I have one for it. Stop by after work if you need it. Actually. text me your address/directions and i will stop by with my GS :) . I need to drive it around.
Moe
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
There is an easier way change the Union Bolt on the oil/water cooler with a 2JZGE one it haves a 10mm hole in it just screw it in there your done! you may have to notch the cooler a tad bit to seat it all the way down
