oil pressure sender question.
grimreaper
2,180
Dallas
I had higher readings in my oil filter head port then at the block itself. Might try at the block and on the fliter head and see if you have different readings.
mk3sons
206
New Hampsire
well i have a port on...
the oil exit from block
oil return on block
one pre-oil filter on oil filter head
one post-oil filter on oil filter head
Think the oil return on the block would be best?
jdub
Feb 10, 2006
10,730
Valley of the Sun
You want to measure pressure at the block oil channel that feeds the bearings...i.e. the stock location. That is what actually matters after all ;)
suprajimbo
Hammond, LA
I'm not trying to jack your thread, but whats the easiest way to remove the stock sending unit while the motor is still in the car. Its a 7mge?
mk3sons
206
New Hampsire
I thought you needed to have the stock one hooked up as well?
If its the same as a 7mgte i just took of the intake and used some good ol' slip joint pliers. got a little scratched up but it worked.
jdub
Feb 10, 2006
10,730
Valley of the Sun
The ECU does use the input from the stock sensor. There's another fitting forward of the stock sending unit that blocked with a screw - it's the same thread size as the stock sending unit.
An excellent way to turn your oil sender into a paper weight. Under the sender dome, there's a 14mm hex on the fitting itself. You can get a shorty wrench on it.
mk3sons
206
New Hampsire
Jdub thank for the superb info, once again! couldn't get the damn thing out though >:eek:. Ill be pulling the engine once again on my upcoming 45 day license suspension to replace the oil squirters change the clutch and shim the oil pump! then that gauge will be in for life!
suprajimbo
Hammond, LA
Thanks, I thought there might be a way to get a wrench on it but I wanted to be sure.
