I've got a fully rebuilt motor. Forged internals, balanced, many other mods... Yada yada yada... Currently approaching 3000 K on the new motor... (1850 Miles)
It's got a stock Toyota oil pump, shimmed 5mm
I'm running Castrol Syntec 10w30
My upgraded Ct26 started to smoke about 300 K ago, popped it off, major shaft play. In/Out and side to side.
The motor has very high oil pressure, the question is, how high is too high?
Currently the pressure looks like this, read of a Defi link gauge, with a defi oil pressure sensor.
I have not pushed the car harder than 50% throttle or over 4500 RPM, as it only has street tune currently.
Cold idle at 1000 RPM: 85 PSI
Warm idle at 1000 RPM: 20 - 25 PSI
3000 RPM, warm:45 PSI
4500 RPM, warm: 55-60 PSI
Are these numbers anything to be concerned about? If my oil pressure continues ramping up accoreding to RPM, it's likely I'll see 100 PSI at 7K RPM, hopefully not. mMy turbo dying likely may be the aftermath of a past spun bearing (Rod knock = turbo oil starvation) on the old motor I had it on? Could have been a number of other things, IE Improper priming, poor vacume...
Some input would be greatly appreciated. I'm going to a bigger, badder turbo and can't afford to blow/rebuild it.
Thanks,
- Kev
Thanks,
- Kev
