oil in the air filter
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
when it happened to me, my turbo bearing was blown to hell...
when I took it off, the bearing fell out in 3 pieces...
check shaft play on it, it's probably gone and hope your oil pump screen does its job..
paradox616
472
Melbourne, Australia
oil can also enter the intake via the crankcase ventilation hose which could indicate excessive blow-by, this is the breather that goes to the top of the rocker covers to the throttle body & accordion hose (ironic as the 7m has no rockers)
remove the accordian hose and inspect for an oil trail.
Heavy D
358
worcester, ma
i had the same problem, my oil seal in the turbo was no good, i have perfect bearings on the turbo, just the seal was blown, soo much oil that the intercooler pissed out oil, like if i was draining the oil pan
mista_sup
211
atlanta
cool i will look into it today and see. i have an upgraded ct26 with a 57 trim wheel where will i be able to get the seal if thats the problem??
paradox616
472
my 57trim looks near new and has a blown oil seal on the exhaust. does your car have any compression surge/turbo have any shaft play? Pull off the breather and check it for oil residue. should take 30 seconds.
as for the seal the core is the same as the standard ct26, just larger wheels fitted and the housings bored out. its still a ct26...
