Oil filter relocation help needed
Mr. Y
80 miles away from Kremlin
Hello guys.
I'm using Permacool relocation kit ( http://store.summitracing.com/partd...&N=700+4294817872+4294907680+115&autoview=sku ) and it works well, but I'm worried about rubber hoses.
So I want to switch to SS fittings and lines.
The question is: what fittings should I use with that relocation kit? In other words, what thread is used on adapters? Is it 3/8NPT?
PS: I can't just measure because I dont understand what "3/8 npt" or "1/2 npt" means... we use metric system here.
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
in the kit, at least according to the replacement parts, it uses a 1/2'' NPT to 3/8'' hose barb. so you want a.......
and you use sealant on the NPT side (into the filter housing adapter) but NOTHING on the AN fittings, they create a leak proof seal if installed correctly.
1/2''NPT to -10AN fitting
http://store.summitracing.com/partd...906751+4294906674+4294906745+115&autoview=sku
those should be it. and then you obvisouly need a -10 hose end, and then some -10 hose.
http://store.summitracing.com/partd...090B&N=700+301753+4294906713+115&autoview=sku
http://store.summitracing.com/partd...086B&N=700+301753+4294906713+115&autoview=sku
http://store.summitracing.com/partd...087B&N=700+301753+4294906713+115&autoview=sku
jdub
Feb 10, 2006
10,730
Valley of the Sun
You want 1/2" NPT for the fitting on the adapter and remote filter head. 3/8" is too small IMO.
Selz202
More than Regular Member
May 1, 2005
248
Black Diamond Wa
Rennat;1180834 said:
The closest match to 1/2" is going to be -8. So you want a 1/2" NPT to -8AN male/male fitting. I believe you will need 4 of them.
Here I narrowed it down to the fittings you want: http://store.summitracing.com/egnse...94906748+4294906674+4294906753+115+4294906747
I suggest Aeroquip or Earls...
Tim
Russian70
Russia, Moscow
www.supramania.ru
Mry it is easy to ask about what components(-8an 3/8npt клмн еёжз & ect) you need for your relocation kit to replace goodyear rubber hoses.
P.S. Will u present me rubber hoses?
grimreaper
2,180
Dallas
my understanding is -8an is good for dd and street use, race use: -10an.
You can go with larger AN size Hose (AN-10) if you want...this is especially useful with a shimmed pump, but not required for most motors. -Jdub
jdub
Feb 10, 2006
10,730
Valley of the Sun
It's more of what level of HP the engine is built for. Fully built motor for the 400-450 HP level and above, I'd go with -10 lines. Plus a few other modifications to the oil system ;)
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
well according to this threads from previous months. he has a T67 turbo and some 680cc injectors... soooo i would really suggest the -10 then.
this man is power hungry! haha
Mr. Y
Okey, heres my story:
I wanted built 7M with pt67dbb and supporting mods... But had some problems with engine management (Haltech E8) and couldn't deal 720cc injectors with E8... So I went AEM.. Money and time were lost and my engine wasn't still built (internally stock except MHG) till now... But i've tried AEM tuning, some higher boost with water/meth injection and so on... I made everything work as it should at last! So past summer can be called "education, trial and error" for me...
Now I want to build my setup reliable... Forged internals, meth flow sensor, big warning lamp for oil press/fuel pressure/water temp... And rubber lines in my relocation kit don't look too reliable (althought they handled at least 5K miles).. That's why I want to go SS lines.
PS: Thanks for input guys
I look at the system as a whole, each 90 degree fitting is equal to 10 feet of the same inside diameter hose so if there are a few 90's I'll automatically go -10 on the fittings and hose no matter the end use.
I personally use AN Pushlock fittings and good quality rubber hose as I don't think/feel braided hose is warranted in an automotive application other than for high pressure lines or lines that live in high heat areas. (ie brakes, powersteer pressure or turbo supply/drains)
Selz202
May 1, 2005
248
Black Diamond Wa
Same here, this is what I use: http://store.summitracing.com/partdetail.asp?part=AER-FCV0820&FROM=MG
This is much simpler and will last quite awile, yea eventually it will fail. Won't be for a long time though.
