I just had a new motor put in and i think the cam timing is off a little. When i first started it, the idle was at 1500rpm and it started overheating. There was also a loud clanking noise come from the head. I set the crank at 0 degrees and even with the cam gears align, the top of the cam lobe was not facing up.I set the ignition timing to 10 degrees and it ran ok but the clanking noise was still there. Adjusting the cps did stop the clanking for a second but it ran like shit. That was all yesterday. Today the car wont start even with adjusting the cps and resetting the ecu. Any help would be appreciated
