My Thread from November.
Never got any response. Still have the problem, I've run tests with 3 different ECUs and 2 known good O2 sensors. I have some time today & will put O'Scope on output from O2 to confirm voltage, but I recall it's .5V and varies with 'engine performance'.
I'm just finishing the wiring on my 1JZ. Have a problem with O2/ECU. It's been running very rich and fouling the plugs & O2 sensor. It continuously throws a code 21 - O2. It is impossible to confirm that it clears, because as soon as the key is turned ON, the code (21) is present.
All O2 wiring has been triple checked, O2 replaced, voltages checked. Old and new O2 both have signal output within specs when warmed up. Positive voltage present on O2 heater circuit as soon as key ON. It never gets a signal ground from ECU to actually energise the heater circuit.
Dr. Tweak told me he doesn't think the ECU will throw a code 21 (O2) just because the heater circuit between the ECU and the O2 is bad. He was not positive, but said he thought that the actual signal from O2 to ECU has to be missing.
Looking for confirmation/second opinion. I trust Dr. Tweak, but have no way to confirm. I would appreciate confirmation from other owners and possible solutions.
